what kind of weight can a first gen handle
Old Apr 24, 2011 | 10:21 AM
staylorw250's Avatar
bulb what kind of weight can a first gen handle
my dodge is a 89 with the 727 non overdrive tranny how much weight can this thing handle without hurting itself whats the most amount of weight this i could haul
Old Apr 24, 2011 | 10:14 PM
olsmokie47's Avatar
Wow whare is everybody? I'd like to know to
Old Apr 25, 2011 | 07:22 AM
RSWORDS's Avatar
Look on your door jam for the gross combined weight. You truck is around 6k.
Old Apr 28, 2011 | 08:06 PM
the tag is there but its not readable
Old Apr 29, 2011 | 07:00 PM
dark knight cummins's Avatar
just load it up. i have a 92 with a 518 OD and i used to pull a tri axel flat deck loaded was about as big as was safe at the time. that was years ago, trailers are better now though.
i plan to pull my 10 ton tandem axel dump trailer loaded this year as well as my 26ft covered drag car trailer. they have solid engines and solid drive train. they can handle weight
Old Apr 29, 2011 | 07:08 PM
pukie370's Avatar
your weekness is tranny. Get a built tranny and you can pull 20k easy
Old Apr 29, 2011 | 08:48 PM
thats what i wanted to hear i would like to say i will put a 5sp but i doubt that will ever happen but what u guys are saying is that all the power is there but that tranny wont get it to the ground
Old Apr 29, 2011 | 09:36 PM
white93's Avatar
I used to tow 20k with my old '92 and it did fine. I've been towing 20k+ the last couple weeks with my current 1st gen and I personally think the 518 handles towing better than the getrag does. If you tow that much I would recommend getting a temp gauge and go from there as far as cooling.
Old Apr 30, 2011 | 07:49 PM
C16 power's Avatar
My 518 sure as hell don't, rebuilt it and 10k miles later slipping 3rd gear. It's a sorry trans IMO. The most I've pulled was 14k combined, few very short trips.
Old May 1, 2011 | 06:47 AM
KD93's Avatar
x2.
Guess they didn't rebuild it right. My truck, when it belonged to my wife, went all over the country towing 20k on a stock tranny and engine. The only problem she ever had was the headlight switch caught fire.
