is my turbo going out?
Old Apr 23, 2011 | 10:08 PM
oil_burner's Avatar
Default is my turbo going out?
went out to move my fuel plate some and when i took the intake horn off the intercooler tube there was some oil in the boot. im assuming it has to be coming from the turbo. am i going to have to but another turbo or could i change the seal myself or what?.... assuming it is the turbo. is it ok to drive like this or should it be takin care of like right now? thanks
Old Apr 23, 2011 | 11:47 PM
big bad diesel 416's Avatar
Site Sponsor
Passing oil is not a HUGE issue but it should be taken care of rebuild kits are about 80-120 bucks and there a cake walk to do
Old Apr 24, 2011 | 06:59 AM
bulldog77's Avatar
Holset HX35 Rebuild with Pics! - Dodge Cummins Diesel Forum
Old Apr 24, 2011 | 09:03 PM
oil_burner's Avatar
so it wont hurt anything if i drive like that for a little while?
Old Apr 25, 2011 | 11:39 AM
bsnyder47's Avatar
Make sure you have no shaft play either
Old Apr 25, 2011 | 03:24 PM
oil_burner's Avatar
yea theres is very very minimal shaft play, its just letting oil by
Old Apr 25, 2011 | 07:26 PM
jayman54's Avatar
if its just a light coating ur ok..if its actually like soaked and wet all the way to ur intake then i might be fixing it
make ur your airfilter is ok... a good restriction will cause oil to pass under heavy boost conditions
Old Apr 25, 2011 | 07:46 PM
oil_burner's Avatar
its got a newer filter on it, deffinitly more oil in there then usual but not a ton....anyone ever used that rebuild kit on ebay for $40?
Old Apr 25, 2011 | 07:55 PM
Site Sponsor
dont be cheep its not worth the 40 bucks now for the 350 or more to replace the whole turbo later get genuine holset JMO
Old Apr 25, 2011 | 08:04 PM
oil_burner's Avatar
yea thats kinda what i was thinking, was just wonderin if anyone knew anything about the cheap ones
