Fan Clutch going out
Old Apr 23, 2011 | 08:18 AM
MIGUEL 76442's Avatar
Default Fan Clutch going out
My fan clutch is starting to go out. Someone at work said to use a flex fan i think thats what he called it. If so do yall have a part number and where do I order one or should I go back with the fan clucth. Thanks for yall's input.
Old Apr 23, 2011 | 08:40 AM
RAW's Avatar
RAW
Flex-a-lie perhaps?
262 Dodge Cummins Diesel
There are also these:
Derale Performance Dual Electric Fans
Do you do a lot of towing, or is the truck more of a commuter? The factory fan can pull more CFM then these electrics can, so goes the rumor.
Old Apr 23, 2011 | 09:41 PM
TugBoat's Avatar
Flex fans are junk. They need more power to turn than a clutch set up. Had a friend lose some fingers cause one of these came apart
Old Apr 24, 2011 | 12:09 PM
Thanks I may just use the stock fan clutch.
Old Apr 24, 2011 | 12:23 PM
Uncle Bubba's Avatar
Check out this thread. I have been running these dual fans on my truck for over a year and tow heavy in the heat of summer. I have yet had to use the high settings even hauling 20,000 plus pounds in 100 degree heat. Total cost was less then $100.
https://www.dieselbombers.com/5-9l-r...-write-up.html
Old Apr 25, 2011 | 02:14 AM
banditsdiesel's Avatar
the electric flex-a-lites are great fans. i had them on my truck for 2 years and dyno proved 23 hp at the wheels. and 2 mpg with them. cooled great in all weathers and the a/c worked much better. only reason i took them off was towing really heavy loads they dont work quite as well. im bout to put them back on now though, dont tow anymore. as far as the flex fan them drawing more than a clutch fan thats crap and a big load of it. they are lighter and less weight takes less power to spin. we put one on a 02 in the shop and removed the clutch and it cools perfect.
Old May 16, 2011 | 09:34 PM
Blue Monster's Avatar
i love my flex a lite fans!!!!!
Old May 16, 2011 | 09:47 PM
Hey Blue Monster would you happen to have a part number on that and where to get one.
Old May 17, 2011 | 12:12 AM
the 94-02 is flx-262 03 up is flx-264
summit has them and anyone whos a flex a lite dealer can get them. we can get them here in the shop.
Last edited by banditsdiesel; May 17, 2011 at 12:12 AM. Reason: Automerged Doublepost
Old May 17, 2011 | 10:31 PM
Thanks I will check it out.
