Code
Old Apr 22, 2011 | 03:10 AM
Cody Cummins's Avatar
Default Code
Recently i checked the codes with my smarty, didnt have a check engine light or anything but i did get 1 code, it was the p0236 code, smarty said it was for MAP sensor too high too long i have no problem getting boost i hit 70 psi no problem, also im running the smarty on fuel saver mode, any thoughts on this? also when trying to use it to do an ABS update as soon as i hit the ABS update i got a connecting... after that i got CCD Error #93 program aborted any thoughts on this as well? thanks!
Old Apr 22, 2011 | 09:09 AM
biged681985's Avatar
as far as the boost code, it dont seem like u have any type of programmer on the truck besides the smarty. if thats the case, could very well be from u making 70psi when you stock map sensor wasnt suposed to read but 25 it needs to be tricked into not knowing that it isnt making that much pressure.
now the abs deal, idk.
Old Apr 22, 2011 | 11:14 AM
Default Re: Code
So basically setting the smarty to boost fooling would stop that code from popping up?
Old Apr 22, 2011 | 05:48 PM
ya it should
dwmeehan
Sep 6, 2015 04:20 PM
Saams69
Jul 20, 2015 11:21 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Backhoeman
Jan 3, 2015 12:53 PM
