vacuum?
Old Apr 21, 2011 | 08:52 PM
txswm58's Avatar
Default vacuum?
my ac only blows thru defroster vents and cruise control stopped working.where is a good place to start?
Old Apr 21, 2011 | 09:05 PM
RAW's Avatar
RAW
At the vacuum pump, located below the Injection pump. Look for a black hose with a rubber boot, it needs to be connected to the vac. pump.
Old Apr 21, 2011 | 09:17 PM
txswm58's Avatar
it is connected checked all that could vacuum pump be bad? am i even on the rite track?
Old Apr 21, 2011 | 09:40 PM
RAW's Avatar
RAW
I'm pretty sure your on the right track. Both cruise and the vents are controlled by vacuum. Start the engine, remove the line to the vac pump, and put your finger on the vac pump. Feel for the suction, if there is suction on you finger it should be OK.
Old Apr 21, 2011 | 09:42 PM
7.3 Cowboy's Avatar
Default Re: vacuum?
Make sure the line ain't cracked.
Sent from my DROIDX using Tapatalk
Old Apr 21, 2011 | 09:50 PM
txswm58's Avatar
there is vacuum but its very little
Old Apr 23, 2011 | 01:55 PM
pukie370's Avatar
Your on the right track, look for bad hoses, there is a coupling right above turbo that can melt from heat. I would also put vac gauge on pump i dont know for shure but i would asume you should have 10-15 inch off vacume maybee more.
DC_DC41
Jul 16, 2015 09:56 PM
DeLuzGN
Mar 17, 2015 08:08 AM
cutthroatxxx
Mar 13, 2015 08:41 AM
LTreis702
Feb 14, 2015 12:52 PM
casper83
Jan 21, 2015 09:36 PM
