COOLANT LEAKING OH crud!!!!!
Old Apr 21, 2011 | 06:50 PM
52deluxe's Avatar
Default COOLANT LEAKING OH crud!!!!!
Well I've been posting alot lately!! It seems I have a coolant leak !! I was changing my front diff oil as part of routine mnt when I saw a slight amount of coolant on the front of the engine near the oil pan!! Well I took it too the dealer and they said they pressure checked it all in about 15 minutes!! They could not find any thing even after I showed them the where it was coming from !! I took it too a trusted local independent and we both looked with his flashlite and it looks like a possible head gasket!! I go in next tuesday thank God I bought a extended warranty thru my credit union they have already paid for a new injection pump and frt axle ujoints and they claim that this is a covered repair !! The dealer claimed I had the wrong coolant in it just by the color of it !! I bought it at 49,000 it now has 83,000 on it!! Hope the dealer is wrong and I hope its under the warranty I paid for!! Wish me luck!!! Jeff
Old Apr 21, 2011 | 08:13 PM
biged681985's Avatar
good luck jeff. its a great thing to have it under warranty. the 6.0 are very prone to hg failure. hopefully its covered under warranty. it can get spendy if it aint
while they are doing it u should have them install studs to help prevent it from happening again
Old Apr 22, 2011 | 07:56 AM
steved's Avatar
Sounds like the water pump...$50 and about 30 minutes to fix.
Old Apr 22, 2011 | 06:45 PM
52deluxe's Avatar
I thought it might be but its coming from right side of the front of the motor by the water neck where the upper raditaor hose is!! I guess by the valve cover and down where the head mates too the block!! But the guy at the warranty company said I bought the good plan so it should be covered!! I wonder are the head bolts the one use kind or not ?? And how much for a head stud kit??? thanks for yours and everyones concern this is the best site for advice just plain support!!!
Old Apr 25, 2011 | 03:43 AM
dangerous1965's Avatar
6.0?? Thought this was a dodge big ed?? Great that
it's covered! Head studs will cost you 400. and zero to install! Since it will be torn down!
Old Apr 26, 2011 | 10:41 AM
52deluxe's Avatar
YEAH its a 2005 dodge cummins bringing it in too a shop today not the dealer !!!!!!!
Old Apr 26, 2011 | 02:48 PM
opps my bad ya
the dodges are prone to poping the HG there under the thermostat housing. currently fixing one that is leaking there right now, and have done 4 others leaking in the same spot. lastset of studs i sold was 430 plus shipping. its good insurance for the next time. good luck
Old Apr 26, 2011 | 05:26 PM
52deluxe's Avatar
Well it looks like it was leaking from upper rad hose in between the braiding in the hose !! so Im going too replace the upper and lower hoses and flush the system . I bought 4gals of coolant from dodge and the hoses so going too tackle when the lower comes in sometime tomorrow!! I understand it holds 7 gals of antifreeze so 3.5 gals coolant 3.5 gals of distilled water should be good!! I had too pay a shop to tell me this!! At least they knew what they were doing ,I think I could have figured it out if I hadn't been in such a hurry to get it fixed last week I was super busy so I didn't take the time too investigate it myself! OH well it only cost me $63.00 to diagnose it and another 100.00 to do the flush and new hose's myself!!
Old Mar 20, 2015 | 04:47 PM
05cumminsdsl's Avatar
Default coolant leaking in front passenger side
Sometimes there's a small amount of coolant that leaks close by the oil filter the big coolant hose will have coolant on it which drips as if the coolant is dropping on that hose from up above ?????
Old Mar 21, 2015 | 01:17 PM
water pump is leaking getting flug by the fan!
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
dieselpowa
Feb 7, 2015 10:07 PM
Stox5225
Nov 18, 2014 01:04 PM
gmcmanis
Nov 9, 2014 04:49 PM
