Which injectors for my setup?
Old Apr 21, 2011 | 05:17 PM
nagloc's Avatar
Default Which injectors for my setup?
I have a '99 with an airdog 100 and edge ez. I'm looking to maximize fuel economy and for the ability to pull a 33' 5th wheel total rolling load around 16k without too much effort. From reading this forum I have gathered that adding some injectors in the 65 to 100 hp range can boost fuel mileage and performance.
What do you guys suggest?
Old Apr 21, 2011 | 08:51 PM
biged681985's Avatar
pulling a 5th wheel, i dont see injectors helping fuel milage. it will help the take off though and can help fuel milage if you keep your foot out of it when empty for sure.
for what your wanting to do, i would say anywhere from 50 to 100 would be ok, 100 is getting towards the limits of you needing a turbo to keep egts low.
Old Apr 21, 2011 | 10:05 PM
alwazjeepin98's Avatar
some argue that bigger injector can help your mpgs... idk i had stock upgraded to rv injectors and i love them. i get 25 with no load.. but i have 5 inch ex. and edge.. so idk. imo you cant go wrong with the rv injectors
Old Apr 21, 2011 | 11:25 PM
01quadcab's Avatar
with stock turbo and towing like that I would only do 40-65hp any more and you will have to drive by pyro way too much to be comfortable while towing.
Old Apr 22, 2011 | 06:22 PM
jcrad's Avatar
Default injectors
Go with the 100's. Thats what i have. I dont do alot of towing but I like them and Im getting 23mpg running 75mph
Old Apr 22, 2011 | 08:06 PM
1SlowCTD's Avatar
7*0.010" Injectors would be your best bet for all around improvement. I would suspect you have gauges already, but these will help with a little more umph to get the load going and have a better atomization to burn the fuel better and keep egt's reasonable.
Nick
Old Apr 22, 2011 | 09:33 PM
nagloc's Avatar
Default Thanks for the replies.
I do appreciate your feedback. 7*0.010 injectors would be in the 125hp range?
Old Apr 22, 2011 | 09:46 PM
1st_gen_puller's Avatar
I would say 65 or 75's honestly.... would be perfect...
Old Apr 23, 2011 | 08:43 AM
crzycummins's Avatar
60 range will give you a bit more go without dumping in fuel on that stock turbo. Should keep egt's reasonable while giving you a little more confidence on grades. Just my .02
Old Apr 26, 2011 | 08:09 PM
1SlowCTD's Avatar
7*0.010" are 100HP when you have to have HP ratings.
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
