How often should I change Tranny fluid?
Old Apr 21, 2011 | 12:16 PM
bullet5.9's Avatar
Default How often should I change Tranny fluid?
I have an 06 with an ATS tranny, just wondering if anyone knows how often I should change out my fluid and have it serviced. What brand of fluid should I use or does it matter? Thanks!
Old Apr 21, 2011 | 05:18 PM
deerslayer1's Avatar
every 30k i work for dodge dealer so i use mopar fluid cause its free
Old Apr 21, 2011 | 06:43 PM
bullet5.9's Avatar
Are there any other brands of fluid that are better or worse?
Old Apr 21, 2011 | 06:53 PM
52deluxe's Avatar
use what the owner manual reccomends or call ats and ak them. Hope all goes well with the change!!
Old Apr 21, 2011 | 09:01 PM
bullet5.9's Avatar
Thanks, I think Im going to have it serviced at a shop so I dont screw it up.
Old Apr 22, 2011 | 07:53 AM
steved's Avatar
Probably tell you any Brand-name ATF+4...I tended to drain and fill mine more than most, just because.
If your pan doesn't have a drain, have one installed...it will make life much easier for future fluid changes (you don't really need to change the filter or adjust the bands every time).
Old Apr 22, 2011 | 02:52 PM
i installed mag tech trans pan has drain plug in it and i think it holds approx extra gallon of fluid
Old Apr 22, 2011 | 06:09 PM
bullet5.9's Avatar
I think mine has a drain plug, I will just have to figure out how much fluid it holds. I think I can call ATS for the capacities.
Old Apr 25, 2011 | 03:36 AM
dangerous1965's Avatar
Drain the TQ too! If it has a drain plug! Most aftermarkets do! With that drained expect to use about 14 to 17 quarts!
Old Apr 25, 2011 | 10:50 AM
bullet5.9's Avatar
Thanks for the advice. Now I gotta get the job done! Another Quick question: What is the Governor Pressure Solenoid? Thanks.
