Which 6.7 Bombs?????
Old Apr 21, 2011 | 08:34 AM
vcustoms86's Avatar
Default Which 6.7 Bombs?????
So I am going to pick up my next cummins this weekend. Its an '07 with G56. Im planning on DPF delete, EGR delete, intake manifold, air intake, Mini Maxx, and 4 inch exhaust. Is a wastegate something i should consider too? Also was thinking of putting water/meth on to help mpg and clean out the motor of all that soot. Anyone got anything else i should consider?
Old Apr 21, 2011 | 08:45 AM
Jagsdiesel's Avatar
Diesel Bombers Sponsor- Jags Diesel
Without the EGR you have no waste gate. The VGT on the 6.7 has a real small exhaust housing and causes high drive pressures. Waste gate if your going to push the truck hard. Also look into a set of head studs right away.
Old Apr 21, 2011 | 09:25 AM
vcustoms86's Avatar
Truck wont be pushed hard. Just tired of driving the 24v everyday. Too much money in it. The 6.7 will be the daily driver and pull the goosenecks every now and then. Most towing will be handled by the 24v though. Are the high drive pressures lifting the heads that often?
Old Apr 21, 2011 | 09:34 AM
coors_man_2005's Avatar
i have been told by a few ppl that they dont think the waste gate is really worth the money there still having the same issues i would say put studs in it and keep the boost in the lower ranges
Old May 1, 2011 | 11:36 PM
Deleted09's Avatar
I did several flow improvements from the intercooler to the engine intake. I started with a boost tube upgrade, it is larger diameter than stock, next was the throttle valve delete. In the throttle valve delete was located my grid heater. The stock grid heater location is restrictive, and it is less restrictive in the throttle valve location. I did not buy an intake, I just took a cone stone and ported it. I opened up the outlet side where the grid heater used to be. I also used a manifold on top of the head, the aftermarket manifold is smoother inside, and slightly higher , for more flow.
This whole system is too small for this size of engine, and there are replacement parts for all of it.
Old May 2, 2011 | 08:09 PM
dodgeram082500's Avatar
The drive pressures are not lifting the heads but high drive pressure is a sign of high cylinder pressure which do cause blown head gaskets. IMO wastegates are not worth it they are more of a band-aid to hide the problem but not fix it. I blew my last gasket with a silver bullet, wastegate, 625 studs, and the blackmaxx/mp8 stack. anyhow just my .02 there are better things to spend your money on than egw (unless your using it to tune twins)
Old May 3, 2011 | 09:43 PM
vcustoms86's Avatar
Deleted09 did you see any increase in mpg after you added all of that?
Old May 3, 2011 | 10:48 PM
deleted 09 what head gasket you repair with
Old May 4, 2011 | 07:20 PM
556hunter's Avatar
Rooster24v
Price Quote - Request A Price
Aug 26, 2015 06:24 PM
brand97
Jul 21, 2015 09:16 AM
Adam65
Jan 9, 2015 11:50 PM
4estlee
Oct 7, 2014 07:47 PM
