Fishing for help
Old Apr 20, 2011 | 02:53 PM
Fishman's Avatar
Default Fishing for help
Just joined up people have already learned some about the fuel system on 6.5. Checked LP all good. Air intake all good, next clean-up grounds on firewall. Truck is a "97" w/ 109,000 mi. The guy I bought it off had $3,000.00 work done on it and became overwhelmed He hasn't got all of the receipts. I can see new intake gasket. It has new PMD mounted on intake,"Heat-Sync" Assume that is not a bad thing. Truck is coding out, do not have diagnostic equipment. The symptoms are a lot like I have been reading about, drive fine for a while then out of nowhere lots of black smoke and loss of power. I let off accelerator then tromp on it comes right out of the fit. The truck has sat for a while maybe a year so I have run Power Service through two tank fills. It must be loading up for some reason can't know why. Any ideas would be greatly appreciated. Can see that IP is new or reman.I bought the truck so to use bio. Not interested in straight veggie conversion although have done one in past years.
Old Apr 20, 2011 | 03:19 PM
Crazy's Avatar
well if the truck is drivable go to autozone have the codes read they will do it for free and this would help us out to help you out
Old Apr 21, 2011 | 05:47 AM
Fishman's Avatar
Default 10/4
I have to locate an Autozone facility in Maine that is definitely next step. Thanks for quick reply Crazy
Old Apr 21, 2011 | 05:54 PM
Woody35's Avatar
i was just in maine for a college visit and they seemed like really nice people. i dont see why any autoparts store might let you use a code reader for free. i saw a lot of napas when i was there. by the way the pmd on the intake isnt a great setup. behind the bumper is the best or on the injection pump is the second best spot.
Old Apr 24, 2011 | 07:25 PM
Fishman's Avatar
Default Fishing is slow
Found a couple of Autozones within 50 miles so will check them out also maybe VIP anyway truck seems to be running a little better maybe could be hadn't been run for so long still must figure out code. Thanks for your input Woody, Welcome to Maine!!!
carid
Diesel Bombers Sponsors
Feb 2, 2015 09:24 AM
