marine injectors?
Old Apr 20, 2011 | 02:04 PM
01_cummins's Avatar
Default marine injectors?
so a truck im lookin into buying is nice looking haven't been to start it yet but the guy is telling me it has a monster mack turbo and marine injectors. im not sure about either of those modifications so i figured id ask and see if anybody else has any helpfull info. the guy has no paper work to proove the marine injectors or turbo i assume the turbo will not look like the average holset turbo but will it sound rougher or meaner with the marine injectors? thanks ya'll
i just need to know how to tell if it does or doesn't have aftermarket injectors honestly
Last edited by 01_cummins; Apr 20, 2011 at 02:04 PM. Reason: Automerged Doublepost
Old Apr 21, 2011 | 01:00 AM
EasternAggie's Avatar
the turbo will be easy to tell Im not sure how to tell on the injectors
Old Apr 21, 2011 | 08:35 AM
biged681985's Avatar
only way to tell what injectors it has would be to pull it and send to an injector shop. u can guess a lil by how much it smokes, but if it has a bigger turbo, then that wouldnt help out much. so your back down to pulling one out and sending it in for testing.
Old Apr 21, 2011 | 09:27 AM
95 cummins ole smokey's Avatar
pull the injectors and look at the holes in the bottom the bigger the holes then there aftermarket, i compared mine to the stock ones and easyly saw the deffrince
Old Apr 22, 2011 | 08:24 PM
bsnyder47's Avatar
with a bigger turbo you would need more fuel so it would make sense that he would have bigger injectors
Old Apr 22, 2011 | 10:24 PM
bulldog77's Avatar
One way to tell is if the pump has 181dvs and it seems like it has a miss or stutter in the lower rpms(This may be a very skeptical way to tell). Only other way is to pull a injector have it checked out. From my experience, I was running 370 marines with stock 181dvs and sounded like I had a small miss at idle and it would stutter between 1200 to about 1700 rpm. Installed the .022 dvs and she smoothed right up. But the only real right way to tell is to pull a injector and have it checked.
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
Original_big_rod
Feb 24, 2015 10:39 PM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
