torque specs
Old Apr 19, 2011 | 06:40 PM
dieseldude848's Avatar
Default torque specs
hey, does anyone kno the torque specs for a 4wd 99 2500 front right axle shaft nut, and also the specs on the the wheel bearing carrier flange that bolts to the rotor? its a 4 flange non abs carrier.
Old Apr 20, 2011 | 02:34 PM
1AMatt's Avatar
Site Sponsor - 1aauto
The axle nut is 175 ft/lbs. The hub mounting bolts im not sure
Old Apr 20, 2011 | 09:01 PM
ok thanks. the axle torque spec is the most importent i think for the right ft/lbs. the hub shouldnt be a big deal
Old Apr 21, 2011 | 09:33 AM
1AMatt's Avatar
The axle nut is more important. The hub mounting bolts will have a torque spec, but to be honest I dont think I have ever torqued them. It is a good idea to torque them, but definitely not going to cause your bearing to fail in a month. I searched quickly and found answers from 80-120 ft lbs... Any body have access to Alldata or something to get a spec for the mounting bolts?
Old Apr 21, 2011 | 01:40 PM
whats alldata? dieseldatabase.com?
Old Apr 21, 2011 | 01:57 PM
1AMatt's Avatar
Im sure you can find it at dieseldatabase.com. All data is a website that shops will use. Its automotive repair software basically
Old Apr 21, 2011 | 02:02 PM
ok thanks.
Da Bomb
Sep 3, 2015 10:00 AM
Jun 22, 2015 12:40 PM
Mar 26, 2015 08:10 AM
Dec 27, 2014 03:00 AM
Gizmo52
Oct 1, 2014 02:13 PM
