Replace Motor in 2003 Excursion
Old Apr 19, 2011 | 05:00 AM
JRSWENSON's Avatar
Default Replace Motor in 2003 Excursion
Found out today that I'll need to put a new motor in my 2003 Excursion. (#3 Injector lost it's tip in to the cylinder...)
I have a Bullet Proof EGR Cooler and Oil Cooler on it now so when I swap things out, I want to keep those.
I know the EGR cooler is different and the ICP is in a different location on some. I know of an '06 for $3,900 with 30,000 miles on it.
Is that a good deal?
Can I just swap the '03 intake and exhaust manifolds over to a newer long block?
Anything else I need to verify before I get a different motor?
By the way...
This is a great forum. I'm a new member, but I've been getting excellent information from here for a few years now.
Old Apr 19, 2011 | 08:09 AM
Mdub707's Avatar
I doubt it will work, there is a LOT of variances between the years. Not just EGR cooler and ICP location. I don't think much of it is the same at all actually. Usually the dealer will ask for your VIN to make sure you're getting a similar motor. I've been told to always try and keep the same years. With that said, that's a really good price for that motor regardless.
Old Apr 19, 2011 | 11:30 AM
JRSWENSON's Avatar
Any one have any experience with these guys?
http://www.powertechengines.net/index.html
Rebuild vs. Used. Almost seems too good to be true...
Old Apr 19, 2011 | 02:00 PM
CSIPSD's Avatar
You can swap the long block in without issue... Just swap/adjust the items from your long block to the new one. The heads and block did not change, just some mounting points and such.
Old Apr 21, 2011 | 06:21 PM
JRSWENSON's Avatar
I went down and talked with Ken @ Wild Diesel in Ogden, UT today. He's had some experience with with doing this same thing. Basically he said short block is no problem, but long block is a real pain. It can be done, but not worth the effort.
Old Apr 22, 2011 | 04:51 PM
Mdub707's Avatar
Pretty much what I have read/heard as well.
DCS Doug
Diesel Engine Conversions
Mar 2, 2016 03:03 PM
rowekmr
For Sale
Mar 6, 2015 04:30 PM
Lawrence D. Sanders Sr
Dec 16, 2014 11:52 PM
Dec 10, 2014 08:10 AM
2003powerstroke6.0
Oct 19, 2014 10:04 PM
