BAD milage need help!!!
Old Apr 18, 2011 | 10:52 AM
casexx's Avatar
Default BAD milage need help!!!
04 3500 4X4 DRW crew cab with a CM bed and a 6-speed, has 3.73 gears in it.
pulling 14K getting 6.8MPG on average (hand calculated) has a intake, but no muffler and i believe the cat is still on it. so why it it so bad? it had a bully dog torque dog on it on high. and it's not throwing any codes. should i remove the cat? or what i really need better mileage.
and i pulled the bullydog off just to see if that's the problem
Old Apr 19, 2011 | 04:57 PM
sabortooth's Avatar
Maybe as the engine gets broke in your milage will increase. My 2500 5.9L is getting 21-22mpg hwy. 70000 mi. I am removing the cat this weekend.
Old Apr 19, 2011 | 05:03 PM
rednekroper05's Avatar
I'm not getting that great of milage also in my 06 unloaded but it might be it has a fresh remaned short block. I'm hoping when I replace factory muffler and work the cat I get better milage
Old Apr 19, 2011 | 06:59 PM
coors_man_2005's Avatar
with my 6.7 i get 13 pulling 16,500lb travel trailer when i was mostly stock i got around 7-8
Old Apr 21, 2011 | 05:54 AM
dangerous1965's Avatar
Get a smarty!
Old Apr 21, 2011 | 07:26 AM
What are y'all running as far on the smarty? I have a pod and it doesnt seem to help
Old Apr 21, 2011 | 08:17 AM
biged681985's Avatar
u were pulling 14k and got 6.8 with the bully dog on high? have u checked ur milage since then? u should never pull that much weight with any programer turned on high. has it always got bad milage? what does the truck get unloaded?
Old Apr 21, 2011 | 08:26 AM
NadirPoint's Avatar
Default No Kiddin'
I bet EGT was through the roof and at least 3mpg went straight out the tailpipe in the form of black smoke.
|WYG|SS
Jul 4, 2015 08:31 AM
Dustin M
May 21, 2015 10:19 PM
Feb 5, 2015 12:10 AM
dawnrogerl
Jan 21, 2015 09:10 AM
12vbomber
Nov 11, 2014 10:58 AM
