disconnecting ecm connectors?
Old Apr 17, 2011 | 04:37 PM
98dodgecummins's Avatar
Default disconnecting ecm connectors?
I am needing to disconnect my ecm connectors because i got a p2607 code and i need to check the resistence between the intake air heater relay 2 and ECM. What is a safe way to disconnect the ECM.
Old Apr 17, 2011 | 04:45 PM
wildbill's Avatar
Remove ALL battery connections, then you'll need a few extra tools (allen wrench and a socket w/ ratchet).
Did you check the other causes?
LOOSE CONNECTION
INTAKE AIR HEATER RELAY
SIGNAL CIRCUIT OPEN FROM RELAY TO ECM
SIGNAL CIRCUIT SHORTED TO BATTERY NEGATIVE
ECM
INTERMITTENT CONDITION
Old Apr 17, 2011 | 04:46 PM
wildbill's Avatar
1. RELAY CLICKING
Ignition on, engine not running.
With the scan tool, actuate the #1 Intake Air Heater.
Can you hear the Relay clicking?
Yes >> Go To 2
No >> Go To 3
2. LOOSE CONNECTION
While the relay is clicking , wiggle the wiring harness and connectors.
Does this interrupt the clicking?
Yes >> Repair the poor connection.
Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL). (Refer to 8 - ELECTRICAL/ELECTRONIC
CONTROL MODULES/ENGINE CONTROL MODULE - DIAGNOSIS AND TESTING)
No >> Go To 3
3. INTAKE AIR HEATER RELAY
Turn the ignition off.
Remove the Intake Air Heater #1 Relay.
Check connectors - Clean/repair as necessary.
Measure the resistance between the signal and return posts of the intake air heater relay.
Is the resistance between 15 and 25 Ohms?
Yes >> Go To 4
No >> Replace the Intake Air Heater #1 relay.
wildbill's Avatar
4. SIGNAL CIRCUIT OPEN FROM RELAY TO ECM
Disconnect the ECM harness connectors.
Measure the resistance of the intake air heater relay signal circuit between the ECM connector and the intake air
heater relay connector.
Is the resistance less than 10 Ohms?
Yes >> Go To 5
No >> Repair the open signal circuit from PDC to ECM harness connector.
5. RETURN CIRCUIT SHORTED TO BATTERY NEGATIVE
Measure the resistance of the return circuit between the intake air heater relay connector and battery negative.
I s resistance less than 10 ohms?
Yes >> Go To 6
No >> Repair the return circuit shorted to battery negative.
6. SIGNAL CIRCUIT SHORTED TO BATTERY NEGATIVE
Measure the voltage between the signal circuit of the intake air heater relay and battery negative.
Is the voltage greater than 1 volts?
Yes >> Repair the signal circuit shorted to Battery negative.
No >> Go To 7
7. ECM
Reconnect the ECM harness connectors.
Disconnect the intake air heater relay signal wire and use a jumper to connect it to battery negative.
Turn the ignition on.
With the scan tool, read DTCs.
Did DTC P2608?
Yes >> Refer to the INTERMITTENT CONDITION Symptom (Diagnostic Procedure). (Refer to 9 - ENGINE -
No >> Replace the ECM.
Old Apr 17, 2011 | 04:57 PM
Ive checked everywhere besides the Signal Circuit Open from relay to ECM. Everything else was good.
jeremiah1
Jun 18, 2015 05:01 PM
Zachbishop
May 29, 2015 07:21 PM
klein444
6.2L & 6.5L Performance
Mar 5, 2015 05:13 PM
Lanceomni
Feb 23, 2015 09:26 AM
PerformanceAuto
Jan 15, 2015 12:32 AM
