charging issue... AGAIN!!
Old Apr 17, 2011 | 01:37 PM
jdbigblue12v's Avatar
Default charging issue... AGAIN!!
so i was out side before and letting the truck idle after driving, and out of no where a strange high pitch noise came through the speakers. i looked down at the vlotage meter in the cluster and it was pulsating and seemed like it wanted to move down to 18v. i tuned everything on, lights running lights, hit the brakes, radio, defroster and hazards. nothing happend and it continued to make the noise for about 30 seconds after than stopped and voltage meter dropped down to 14 again!!!???!??!??! im so far confused and am getting sick of electrical problems! some one please help! thanks james
Old Apr 18, 2011 | 06:40 AM
cumminskid92's Avatar
have you replaced the voltage regulator. i have never heard of one jumping around in voltage but who knows with the wonderful 1st gen. electrical system.
Old Apr 18, 2011 | 10:07 AM
isnt the voltage regulator internal?
Old Apr 18, 2011 | 10:41 AM
im pretty sure it is on the firewall. mine was anyways
ok so i was looking around and from what i can find trucks pre 92 have external regulators either on the fender or firewall. 92 and up have the regulators built into the ECM.
Last edited by cumminskid92; Apr 18, 2011 at 10:41 AM. Reason: Automerged Doublepost
Old Apr 18, 2011 | 11:57 PM
i have a 1993 so its built in
Old Apr 19, 2011 | 12:29 AM
crazy clem's Avatar
lots of these trucks have grounding issues. a buddies truck was having issues like yours, we added an new ground to the rad support and that cured it. another issue that we found at the same time was that his battery had a film on it, and we were getting 8 volts from the battery case to ground , maybe that was screwing up the pcm . ithink the pcm regulates the alternator on the 93 . good luck
Old Apr 20, 2011 | 07:27 PM
i re-did all the grounds and it helped but still having problems. what do you mean by film on the battery?
Old Apr 20, 2011 | 10:57 PM
crazy clem's Avatar
It was a greasy type of film like the batt had been overcharging you could actually run your finger across top and leave a mark in the dirt . disconnected batt and cleaned it usual way with baking soda and warm water.
Dec 10, 2019 10:10 AM
norcal6.5
Dec 7, 2014 07:04 PM
Oct 23, 2014 08:10 AM
hemiheath
Oct 15, 2014 11:49 AM
Oct 8, 2014 08:10 AM
