valve top dead center
Old Apr 16, 2011 | 01:57 PM
blazier18's Avatar
Default valve top dead center
how do i find tdc so i can adjust my valves
Old Apr 16, 2011 | 03:46 PM
Red_Rattler's Avatar
High Tech Redneck
http://dieseldatabase.com/b-series-v...ustment/?id=62
Old Apr 16, 2011 | 11:57 PM
Pyro690's Avatar
That pin can be a PITA to move if it hasn't been touched for 100,000 miles or so. Mine would only move till it hit the cam gear, then stop. A lot of lube spray and patience to get it to engage all the way.
Old Apr 17, 2011 | 01:39 PM
blazier18's Avatar
i didnt use the pin i used a close hanger and watched it till the piston pushed it to the top and both rockers were loose then i made a mark adjusted them spun it 360* and did the rest! only thing left to do is flush everything out refill everything change my oil and fuel filter and drive it a few hours and check torque on bolts
RA113024
Mar 13, 2016 07:42 PM
countryboy040993
Mar 21, 2015 04:47 PM
LTreis702
Feb 14, 2015 12:52 PM
Nov 12, 2014 08:10 AM
