need help asap guys thanks
Old Apr 15, 2011 | 08:24 PM
snowboard3r411's Avatar
Default need help asap guys thanks
ok im about to pull my tranny out to swap in a different one. its a 518 auto. how the heck do you spin the motor to get the torq converter bolts off?? theres like no room on the front of the engine to get a socket on the crank shaft to spin it and dont even know if you could anyway. need help asap tho starting this swap in 45 mins thanks guys
Old Apr 16, 2011 | 05:42 PM
tiremann9669's Avatar
You can use a barring tool or i've heard of puttin a socket on the alternator but never tried it.
Old Apr 16, 2011 | 05:47 PM
Gas's Avatar
Gas
Socket on the alternator...better have a gatorback.
Old Apr 16, 2011 | 06:48 PM
lilsixcylinder's Avatar
take a good sized flat head screw driver and pry on the ring gear useing the housing of the trans to pry against
Old Apr 16, 2011 | 06:52 PM
Red_Rattler's Avatar
High Tech Redneck
alternator pulley works like a charm, been there done that
Old Apr 17, 2011 | 10:42 AM
Rusty89Cummins's Avatar
just get a wrench on the harmonic balencer in the front and turn it. thats probly the easiest.
Old Apr 17, 2011 | 10:27 PM
johnfak's Avatar
this is the way I did and my tranny guy did it also
Old Apr 18, 2011 | 11:19 AM
93bomber's Avatar
i used a 1/2 rachet with a short 15 on the harmonic bolts. ive pulled the trans twice and worked fine. good luck
GT_Eleanor
Aug 25, 2015 09:35 AM
willis964x4
9
Aug 22, 2015 12:21 PM
ffmoofus
Jul 25, 2015 10:35 PM
jeremiah1
Jun 21, 2015 06:45 AM
xj_crawler
12
Nov 20, 2014 10:17 PM
