Black then white smoke??
Old Apr 15, 2011 | 04:50 PM
Captainharley6.0's Avatar
Default Black then white smoke??
When i start my truck i get a small puff off black smoke followed by little bit of white or light bluish smoke only last few seconds just noticed it using my auto start. I have my hp bumped up 75 with sniper tuning, egr delete, 220,000km and no codes. I was blowing some coolant but had my system flushed and found out my "new" cap from ford was only holding 9psi none leaking since new cap.
Question is this smoke a future problem that may be lurking??? WhT may cause it.
Any insight appreciated
Old Apr 15, 2011 | 04:57 PM
wrench4it's Avatar
Is the smoke white or light blue, white being coolant, light blue being oil, and when does it do it/
Old Apr 15, 2011 | 05:02 PM
Its white plus i just took truck for drive and when letting off the throttle quickly i got a shuddering noise from under the hood before truck completely warmed up . Maybe veins sticking???
On the egr delete also i dont have the complete kit just blocked off i was told by my mechanic i should get complete replacement because coolant could b leaking inside the cooler. Wants me to get whole kit with new up pipe. Could b my coolant problem eh???
Old Apr 15, 2011 | 05:42 PM
wrench4it's Avatar
He is right, you want to take care of that quick as u can, i just bought a delete kit on e bay for 175, its not polished but for me its good. Good luck
Old Apr 15, 2011 | 06:43 PM
Thanks for the quick replies he is a good mechanic too and more than reasonable! Do u have a link to that kit??? I found sinister with up pipe for 325$$
Thanks
Old Apr 15, 2011 | 07:37 PM
newman's Avatar
Do you monitor your EOT? A EGR delete doesn't fix anything just covers the main problem
Old Apr 15, 2011 | 07:45 PM
Oil and coolant temps are perfect within 5 degrees
Old Apr 15, 2011 | 08:40 PM
ranger518's Avatar
The noise is your extra boost backing out the intake it is normal
Old Apr 19, 2011 | 07:33 AM
madcreekfarm's Avatar
does your truck sputter and miss if you go out in the morning and fire it up and take off without letting it warm up?
Old Apr 19, 2011 | 08:14 AM
Mdub707's Avatar
That would just be sticking injectors, quite common.
It MIGHT be an EGR cooler failure, but I'd be checking a few other things first. You could have glow plug issues and/or FICM issues or possibly even injectors. I would test the FICM, it's easy and free.
