Adding lift pump ,....
Old Apr 14, 2011 | 07:21 PM
reddevil's Avatar
Question Adding lift pump ,....
Im adding a lift pump to the existing pump in the tank , my question is should i also change the fuel line for a thincker one ?? im adding the BD Lift pump if sow, what you recomend
Old Apr 15, 2011 | 08:11 AM
biged681985's Avatar
it is never good to add a pump on top of the other pump. the weaker of the two will be a restriction. so if your intank pump is already going out, it needs removed or it wont allow the bd pump to pull the amount of fuel it needs.
Old Apr 16, 2011 | 08:10 AM
reddevil's Avatar
Ok, sow i took the tank down and made a separate hole for the second pump ,(i dint add one infront of the other and sealed it real good) and it works great , both pumps working together neither is a restriction to the other, i went out last nite and tried it and it sure made a difference..... sow i just need to get me some injectors.humm:
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
