headgasket ?'s
Old Apr 13, 2011 | 11:31 PM
blazier18's Avatar
Default headgasket ?'s
ok i have my head off i need pushrods head gasket and bolts. ok on the torque on the head bolts wats the best pattern and wat torque numbers. when do i start it and let it heat up then retorque? any lube, copper spray, any info? if anybody has a step by step how to put the head back on and know which gasket to pick id thank you for that. need help asap.865 659 0466
Old Apr 14, 2011 | 12:09 AM
1SlowCTD's Avatar
:txt:
There really should be a smiley for this...
Old Apr 16, 2011 | 06:12 AM
blazier18's Avatar
ok i hope i did this right! torqued my head started out at 30 then 70 then 90 then after all studs were torqued to 90 i did a 90* angle more tightenin. only thing holdin me back now is flush the lines and radiator change oil and adjust my valves. whicj i think if i knew how or could find tdc id be in shape. any valve adjusment stickys?
Old Apr 16, 2011 | 08:03 PM
BRE's Avatar
BRE
I would have started when you got to 90 and took it up in 5-10 lb arguments to 130lbs while using the pattern starting in the center and work your way out in a circular pattern. All of which while using new bolts
Old Apr 17, 2011 | 01:41 PM
blazier18's Avatar
hope i didnt mess it up doin that then. that means my bolts are probably at 150 lbs
Old Apr 17, 2011 | 06:26 PM
BRE's Avatar
BRE
Its very hard to get stock bolts to 150lbs with out massive stretch that would make a normal person stop expecially using 90* increments.
