rim back spacing?
Old Apr 13, 2011 | 01:04 PM
01_cummins's Avatar
Default rim back spacing?
i have an 01 dodge 2500 with six inch lift and i need to figure out how much back spacing i can have becuase i run hummer tires but id like to run the two piece rims with them as they are cheap and the right rim for the tires. i just don't know how the back spacing will effect my turning or driving it..im not specificly sure of the back spacing but a friend has told me i need to figure that out before hand.. has anybody ran them or know what the backspacing is and how that would affect the handling of the truck? thanks!
Old Apr 13, 2011 | 02:58 PM
KillStroker's Avatar
I found the best thing for this without having a butt load of different tires around to try. Go get some 1" strap aluminum bout 6ft. Drill holes to mount to lugs. Mark out the diameter of your wheel diamiter so find half way mark. so if you have 16" rim 8"on each side those will be ur first bends. Now guesstimate what you think your backspacing will be or what you want. from that first bend right after the bend where its straight measure out your back spacing. nowbend the rest of the material left. now take the overall dimension of your tire/wheel combo to cut the excess off. now if youtake if off and look at it you should have made what looks like a top hat with the same overall dimension of your tire/wheel combo. attach it to the lugs with lug nuts. Of course your tire should be off during all of this with jack stand in place or jack so truck is level. Start truck and turn wheel full left and full right. Now this may take 1 or 2 tries for figuring out your backspacing but its allot cheaper than buying the wrong rims and a restock fee. This has always worked for me.
Old Apr 14, 2011 | 12:15 AM
01_cummins's Avatar
allright thanks for the info i will deffinatly be trying that also found that the back spacing is a whoppin 7.5 inchs and they guy ran it on an old 84 chevy scotsdale
Old Apr 14, 2011 | 06:40 AM
Wow thats Deep
Old Apr 14, 2011 | 12:48 PM
D-LUX's Avatar
the best way to run those 16.5's are to just get the rims re-centered
then you can set your own back spacing and not worry about it
its what i run on my 84 chevy and their great because their cheap
Old Apr 14, 2011 | 01:44 PM
01_cummins's Avatar
how do ya get them recentered? ive heard about it but it sounds like its probably expensive so i didn't bother readin into it
Old Apr 14, 2011 | 02:26 PM
D-LUX's Avatar
it only cost me 175 for five.. basically just the cost of the steel plate, the labor was free cuzz he owed me a favor
id call up an offroad shop if yall have one local and im pretty sure that they could help ya out
Old Apr 14, 2011 | 03:05 PM
100Dollarman - Military Surplus Home! Military vehicle parts and vehicles
Aug 26, 2015 10:10 AM
Apr 3, 2015 11:50 AM
THMotorsports
THMotorsports
Mar 10, 2015 09:34 AM
Dec 25, 2014 06:10 PM
wvwelder89
Nov 20, 2014 10:26 AM
