Ring gear on flexplate/flywheel
Old Apr 13, 2011 | 08:41 AM
MechanicalDiesel's Avatar
Default Ring gear on flexplate/flywheel
Has anyone changed out the ring gear on your flexplate/flywheel? mine are bad and my starter barely engages it, so i was wonder how it is done and if its hard. i would rather do this than buy a brand new one. I prefer $30 over $400 any help would be well helpfull
Old Apr 13, 2011 | 10:29 AM
Sudia247's Avatar
I havent replaced just the gear edge on the flex plate, Im sure it would be fine, since its just welded on. Getting to that gear though involves removing the tranny to get to the back of the engine. Honestly, If you can afford a newer flexplate, it would be a good buy.
Don't but OEM, go aftermarket for around the same price, the billet flexplates are so much more reliable, and will last longer. You dont have to worry about ripping the center out if you got the throttle to the floor.
And if youre pullin the tranny, it would be a good to replace the rear main seal as well, just in case since youre already right there.
Old Apr 13, 2011 | 12:24 PM
daveO's Avatar
If you did replace just the ring gear, you'd have to balance it anyway. I would just get an aftermarket one.
Old Apr 13, 2011 | 03:52 PM
tiremann9669's Avatar
Did one on a tractor once just heat it till it falls off lay the new one on the flywheel and heat it till it drops on, not sure if it's the same procedure on a truck. I think on the automatics you just change the whole flexplate.
Jun 4, 2015 09:30 PM
CumminsAtYa
Mar 28, 2015 06:36 PM
Mar 19, 2015 08:10 AM
rtbcoop
Nov 29, 2014 11:33 PM
Spiderman
Oct 6, 2014 09:52 AM
