Changing Chips! Going from Pooper chips to Edge juice or smarty??
Old Apr 12, 2011 | 06:33 PM
Liftedsilvy's Avatar
Default Changing Chips! Going from Pooper chips to Edge juice or smarty??
Whats up guys.
Well now that i got the truck running good im thinking of ditching the superchips and going with something along the lines of a Edge juice or a smarty what would you guys recommend??
I know the superchips is only good for 60HP and 150FTLBs and the Edge is good for 150hp and 300FTLBs will i notice a big diff even tho i already have injectors? I have also been reading of guys stacking the juice with a smarty but i have also heard bad things about the stack even running the no timing numbers on the smarty!
Old Apr 12, 2011 | 06:47 PM
Id highly recommend a Edge CS or Edge CTS.
Old Apr 12, 2011 | 07:40 PM
1SlowCTD's Avatar
EDGE CT OR CTS with Attitude would be the only way to go for a less hands on chip.
Old Apr 12, 2011 | 07:45 PM
OK. What about the older juice with attitude i have a chance to score one of those used?
Old Apr 12, 2011 | 07:47 PM
01quadcab's Avatar
the screen is the only difference so if you can get one for a good price go for it same performance
1SlowCTD's Avatar
Get it, all the CS is is a black version of the old Attitudes.
Old Apr 12, 2011 | 08:08 PM
Ok thanks guys!! I figured it was the same power.
So whats up with the smarty stack is that a NO NO?
Will I gain Any power from a smarty stack or is it a waste of time?
Old Apr 12, 2011 | 11:19 PM
kegs99's Avatar
my brother ran a ejwa stacked with a smarty, and to me it seemed like a big waste. it gave some more power, but not the power you'd expect. I was very unimpressed with it. I think his truck ran the best with just the ejwa with a hot unlock. he later pulled the ejwa and ran just a smarty, he shoulda kept the edge. just my .02 though. don't blow your money on the smarty stack. save it for an intake horn or pulse manifold, you'll prolly see similar results.
Old Apr 12, 2011 | 11:50 PM
RAW's Avatar
RAW
I have a EJWA CTS, Edge Comp, and a Smarty. So far, the best set up is the Comp alone. I may not have the Smarty adjusted to work with the Comp properly, but I've never seen an increase like the Comp has provided.
Old Apr 13, 2011 | 01:42 AM
Do you have the drag comp or the regular comp?
