ECM?
Old Apr 12, 2011 | 05:54 PM
captaincaveman's Avatar
Default ECM?
dead pedal, surges, engine revs tachs up when not on pedal, temp and oil pressure gauges are all over the place. Codes this time are...
P-0393
P-0606
P-1286
P-1475
P-0563
P-0113
P-0123
it will run fine for about 10 miles before it gets 8 kinds of stoopid. Let it sit overnight and I get 10 more good miles out of it. Any way to test the ECM off the truck to be sure that's what it is before I drop a grand on it?
Thanks fellas
Old Apr 12, 2011 | 11:53 PM
RAW's Avatar
RAW
Mods? Fuel Pressure?
How are your grounds?
Performance issues?
Old Apr 13, 2011 | 01:56 AM
dukeboy_318's Avatar
Check your grounds good, also, if you are running a box or programer, get it off the truck, then see if it still does it. Sometimes when boxes go bad, they'll do stuff like that
Old Apr 13, 2011 | 08:55 AM
mods are...
2001 3500 4x4 5spd qdcb, head studded and o-ringed, 120hp injectors, 64mm turbo, raptor 100 lift pump hot rod vp44, edge drag comp with hot unlock
I pulled the box and it didn't make a difference
Old Apr 13, 2011 | 02:18 PM
johnyb59's Avatar
606= ecm death code.
Old Apr 13, 2011 | 04:51 PM
Is there anything else that would cause a 606? Bad sensor somewhere backfeeding? bad ground? short somewhere? I'll do an ecm if that's what it is, I just don't want to throw that much money at it if there might be another cause
thanks
jeremiah1
May 19, 2016 04:58 PM
jeremiah1
Jun 18, 2015 05:01 PM
klein444
6.2L & 6.5L Performance
Mar 5, 2015 05:13 PM
Lanceomni
Feb 23, 2015 09:26 AM
PerformanceAuto
Jan 15, 2015 12:32 AM
