injectors
I have a 2004.5 dodge cummins with powermax cr, phat shaft 66, edge ez, cold air intake and i want to put atleast 200hp nozzles and just wandering if it will run fine with out a new cam also plan on getting cp3 pump with injectors
The thing a cam helps best with is spooling the turbo. If you are going to be upgrading the CP3 and Nozzles at the same time you should be fine. Who's nozzles are you looking at?? PM me and we can narrow down the choices and who has what available>
I was wanting atleast 200hp nozzles from industrial injection but i am new to this stuff so i am not forsure wat the best would be to get and probably a dragon fire cp3 but like i said if there is another company that is better than i would look into it
klein444
Mar 8, 2015 11:42 AM
