abs/brake lights on
Old Apr 11, 2011 | 07:02 PM
dennhop's Avatar
Default abs/brake lights on
I did do a lot of reading, but it seemed to me that most of the issues were with spongy brakes, and these lights lit up. I just replaced the rear abs sensor, but it didn't work. In the mornings, or when its wet outside and I haven't been driving, when I hit the brakes, they lock up immediately on me. After a while, they seem to work normally, but my lights stay on. Any more ideas? I've checked all my fuses, not sure where to go next.
Old Apr 11, 2011 | 07:18 PM
Bill10656's Avatar
My truck has had this since i bought it a few months back, I was told it was just the sensor, but then with repeated pumping...say down a hill in traffic the brakes would eventually hit the floor and not do alot, fluid was filthy so i bled them and replaced both rear cylinders as the nipple had snapped on one. the brakes now feel alot better, and don't seem to hit the deck anymore but the abs and brake light still come up occasionally, I havnlt experienced the locking up you mention...don't think i could lock a wheel on my truck if i tried!
On that note is the ABS really savage on these trucks? as when i hit the brakes super hard they slam on and off quite violently ad the pedal goes a bit soft, not like the ABS brakes in most cars i have owned. is that normal?
Old Apr 12, 2011 | 03:01 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Your ABS and brake light are on? Also do you have ABS in just the rear, of the front also?
Old Apr 12, 2011 | 05:58 PM
Bill10656's Avatar
my and ABS and brak elight ar eon at the same time. I wasn;t aware you could get vehicles tha tonly had ABS on 1 axle I just presumed it had it on both...sorry if that was meant for the other guy
Old Apr 12, 2011 | 07:47 PM
dennhop's Avatar
yeah, I've only got the sensor on the back axle. I found out that the relay is out from under the hood for the abs, but when I plugged a good one in, it shut them off for a few seconds, but then came right back on.
Old Apr 12, 2011 | 08:23 PM
daveO's Avatar
Yeah, my 98 has rear wheel ABS only. I found out based on the sticker on the underside of the hood. Anyway, I've been told that a vacuum leak can also cause your brake/abs light to come on. I haven't verified this myself though.
Old Apr 12, 2011 | 08:25 PM
tiremann9669's Avatar
I powerwashed my frame while I had my box off and after that both of my lights were on for about a week and then they went out. I figured I got water in the connectors for the ABS sensor, maybe you have corrosion in the plug and after changing the sensor you're not gettin a good connection.
Old Apr 13, 2011 | 06:49 AM
UNOH-KID's Avatar
id check for codes this should lead to the main root of the problem or at least send you in the right direction, anything from the speed sensor being off in adjustment to poor conections could cause the light to come on, does your truck have hydroboost brake system
Old Apr 13, 2011 | 07:11 AM
Johnny Z's Avatar
I have the exact same problem and have changed every damn brake part there is....and still it persisit. i have learned to live with it because my brakes work fine and my brake system checked out by a certified mechanic who says all is well.
Old Apr 13, 2011 | 12:26 PM
1AMatt's Avatar
Good idea. Have a shop with an ABS scanner read the codes for you.
carid
Diesel Bombers Sponsors
May 7, 2015 06:40 AM
carid
Apr 15, 2015 07:29 AM
carid
Jan 6, 2015 06:28 AM
bypass-21
Jan 3, 2015 04:47 PM
carid
Nov 10, 2014 02:15 AM
