sound dampening?
is there any good way to make the cab a little quieter ride? the engine is loud, my tires howl, the turbo screams, and on long road trips i cant hear myself think. i was thinkin sound dampening material on the firewall, wheelwells, under and behind the cab. opinions?
get on summit racing, they sell this stuff called "BOOM" its a spray on sound deadening material, its convenient and allows application in tight and places that get wet. its kind of pricey but compared to dynamat it cant be any worse. its not very robust so using it as a floor liner wouldnt be recommended. more than one layer for best results.
Also check out Lizard Skin its a spray on they make a couple different types depending on what your trying to achieve.
http://www.lizardskin.com/pages/sound_control.php
For a low cost sound deadener, buy some cheap old paint and mix it up with sand and apply a very thick coat to your floor boards & firewall.
Here's another alternative that's low cost and bit more professional:
Read the following link. Use what you learn and buy the products on your own from lower cost vendors.
Sound Deadener Showdown - Your Source for Sound Deadening Products and Information
The cheapest place I have found for the MLV is here:
Soundproofing Mass Loaded Vinyl Barrier, Super Soundproofing Co
Lizardskin Ceramic Insulation and Sound Control Spray-on Formula
nothing better than that
Timglow546
8
Jun 3, 2015 10:13 PM
JoeRamsey26
May 29, 2015 06:40 PM
mpmcbride42
Apr 7, 2015 08:28 PM
