Weak throttle response.
Old Apr 11, 2011 | 03:14 PM
mobetter's Avatar
Default Weak throttle response.
I have a 2001 new injection pump, lift pump, no codes set.
Starts and runs but acceleration is weak til I hit 2200rpm then lites up.
Completely stock. I going to do a leak check between the turbo outlet and air horn.
But this turbo is not spooling good up til 2200. Pressure just off idle is about 3psi and maybe about 5psi at 1500 it will reach about 20 at about2500
Old Apr 11, 2011 | 03:38 PM
GuyWithA24Valve's Avatar
Try resetting the APPS. Disconnect the batteries, turn on the key to drain the power, and leave disconnected for 30 minutes. Then reconnect the batteries, turn the key to the on position but do not start! Push the gas pedal slowly to the floor, and then slowly release it (should take about 5 seconds each way). Then turn the key off and it should be reset.
Old Apr 11, 2011 | 09:10 PM
KillStroker's Avatar
Sounds like a case of a stock Cummins. and 235hp.
Try and reset like above and let us know.
Old Apr 11, 2011 | 10:21 PM
mobetter's Avatar
Ok I will try that again.
Old Apr 11, 2011 | 11:52 PM
kegs99's Avatar
i was getting code p0216 and the truck was cuttin out and givin me dead pedal. i reset like he said above and the truck runs great again. Haven't had problems. just for kicks i checked codes again and still got the p0216... but the truck runs good just from resetting the apps
Old Apr 12, 2011 | 07:33 AM
Hes not getting any codes. I think he might be use to driving that duramax around. I remember how laggy my cummins was when it was stock.
Old Apr 12, 2011 | 07:44 AM
RAW's Avatar
RAW
Some ideas:
Is the MAP sensor clean?
Is the AIT sensor clean?
Did you adjust and/or reset the APPS?
Old Apr 12, 2011 | 12:21 PM
01_cummins's Avatar
also id check fuel pressure if you haven't already mine did this when my LP went out and it would cuase the turbo to stall and not boost that may also go with it too as there is no sensor saying your LP is out or low fuel press
jeremiah1
May 19, 2016 04:58 PM
Blair@BD
BD-Power
Sep 10, 2015 12:29 PM
jeremiah1
Jun 18, 2015 05:01 PM
rusty 6.5
Jun 13, 2015 05:45 PM
1stgenswap
Nov 3, 2014 09:45 PM
