FRONT BRAKE PADS
Old Apr 10, 2011 | 06:42 PM
el jefe's Avatar
Default FRONT BRAKE PADS
It's that time again and I was wondering what all of you run for front brake pads. Thanks for your input.
Old Apr 10, 2011 | 08:06 PM
dangerous1965's Avatar
Just a semi metalic medium grade pad will work. One thing that is bullet proof on the dodges are the brakes!
Old Apr 21, 2011 | 10:45 PM
AABEAR's Avatar
MOPAR value line brake pads 03-09 front 56.00 rear 01-09 55.00 if you was happy with OEM you will be happy with these. Prices from Genos
Old Apr 22, 2011 | 07:50 AM
steved's Avatar
The Value Line is not the same as the OE pads...and there have been reports of quick wear too.
I have Raybestos ThermoQuiets on mine...got almost 70k on them now, and they are hardly worn. I should easily get 150k+ out of them, unless something happens.
Make sure you lubricate the slide points and bushings when you have it apart...
Old Apr 22, 2011 | 04:44 PM
el jefe's Avatar
Thanks for all the input. Got them replaced but now I have to put something on them because one side is still squeeling like crazy.
Old Apr 22, 2011 | 05:20 PM
jmac5058's Avatar
I had never thought of that ,you never hear of brake troubles on a Dodge,now if they could transfer some of their brake engineers into the transmition dept.
Turbo67
Jul 25, 2015 02:26 PM
corksil
Jun 30, 2015 06:58 AM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
yams
Nov 29, 2014 09:25 PM
gonza
Chevy/GMC Duramax 01-04 LB7
Nov 17, 2014 03:51 PM
