trany
Old Apr 10, 2011 | 02:19 PM
94Cumminz's Avatar
Default trany
i think i just destroyed my trany!!!!
i will drive in first gear and reverse will not go in to second third forth and fifth gears will just grind when i let of the clutch.. i dont no what happened?
Old Apr 10, 2011 | 07:05 PM
DodgeCummins12v's Avatar
Ill swap my tranny fer yours I have a mint 47re!
Old Apr 10, 2011 | 09:38 PM
94Cumminz's Avatar
i need a manual
Old Apr 10, 2011 | 09:45 PM
1978skidootnt's Avatar
did they all go at once or one at a time?
Old Apr 10, 2011 | 10:14 PM
94Cumminz's Avatar
all at once i was getting on it and i like slipped out of 4 and i put it back in and i let out the clutch and it just stared to grind and i had to lip it home in first
Old Apr 12, 2011 | 01:02 AM
Ok does it not go into gear or does it grind once in gear? Also does the shifter feel loose after the fourth gear problem? It is odd seeing that all these gears went at once i you were to look at power flow through the tranny.
Old Apr 12, 2011 | 06:44 PM
94Cumminz's Avatar
i think i might have striped all the gears
Old Apr 14, 2011 | 12:01 AM
blazier18's Avatar
take your top cover off and look at the forks may not be goin into gear all the way mine did that at first then my buddy came over took a screwdriver played with them for a minute movin them back anf forth never had a problem again.
Old Apr 14, 2011 | 09:13 AM
94Cumminz's Avatar
i hope its that easy
