getting codes again.
Old Apr 9, 2011 | 03:47 PM
vectorboy_99's Avatar
Default getting codes again.
Hello all, I just replaced the VP44 and lift pump system on my truck like four weeks ago. Everything was running fine no problems, then today I went to drive it and it was acting a little weird, then when I stopped I started the truck up and it ran fine, but stalled when I pulled away, it restarted no problem. The check engine light came on and I checked codes with the key on-off-on-off-on method and got codes P1693 and P1689. I have a edge EZ on it that's all, and the lift pump is an Airdog 150. Can anyone tell me what I am to do?
JIm
Old Apr 9, 2011 | 08:43 PM
turbo20psi's Avatar
P1689 (M) No Communication Between ECM
and Injection Pump Module
Data link circuit failure between ECM and fuel injection
pump. Low power, engine derated, or engine stops
P1693 (M) DTC Detected in Companion Module A fault has been generated in the companion engine
control module.
First check the connections on the injection pump.
Old Apr 10, 2011 | 08:34 AM
OK. I will try it. Now last night the check engine light went out and it runs fine. I hope this doesn't end up being a ongoing problem.
Jim
Old Apr 10, 2011 | 07:32 PM
Chilly7's Avatar
I keep getting 1693 also, I have a airdog 100. Let me know if you figure it out.
Old Apr 14, 2011 | 08:49 AM
well on tuesday, we pulled my uncle's new/used 07 cummins home on a trailer, when we took off everything was fine, got to the first stop sign, slowed down and got a dead pedal. restarted the truck and evrything was fine for the two hour ride home. I an at a loss here. Any help would be great. all connections looked good. Could it be the edge EZ?
Old Apr 25, 2011 | 08:46 PM
WEll I have now determined it si the outside temp. After the last problem the temps in my area dropped to the 40's. Today teh temp was in the 50's and it stared the deadpedal bullshit again. HELP!
JIm
Old May 20, 2011 | 07:13 AM
Well after cleaning all connections and not finding the problem. I finally just pulled out the Edge EZ chip i had. Truck runs fine with no problems now. So I guess I spent $1500 on new pumps for nothing. wEll I guess i got better pumps out of it. Now I need a new chip.
JIm
Old May 25, 2011 | 01:10 AM
Natedawg!'s Avatar
have a edge comp and i was getting codes like this and the truck went in to limp mode and wouldnt go over 10 psi and 1600 rpms... ended up being a ground wire was undone
Old May 25, 2011 | 09:58 AM
I will check the grounds again. anyone have any idea how many there are? just so I know I checked them all.
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
schwier94
Mar 8, 2015 06:09 PM
KimberlysTruck
Mar 5, 2015 06:28 PM
Renowest48
Dec 14, 2014 08:36 PM
Altonlee
9
Oct 8, 2014 02:31 PM
