Hydro boost brakes to a 93 Dodge?
Old Apr 8, 2011 | 10:38 PM
95.12v.Cummins's Avatar
Default Hydro boost brakes to a 93 Dodge?
I have a 95 Dodge 99 Dodge and a 93 Dodge, I hate the braking system of my 93. I found a guy on Craigslist parting out his 96 Dodge, is it possable convert the system over from the 93 to the 96 Dodges braking system? And if so whats needed?
Thanks!!
Old Apr 8, 2011 | 11:36 PM
Chevy72's Avatar
I looked into doing the same thing, just haven't gotten around to it yet. I was told it's very simple. all you need is the pump booster and lines. the new pump bolts right in place of the old vacuum pump and power steering pump assembly. I think you need to plug the oil line that went to your vacuum pump. I'm not sure about the mounting to the firewall, the brake pushrod or the master cylinder, but i'm sure it will all bolt up fine. hope this helps good luck.
Old Apr 9, 2011 | 12:14 AM
big bad diesel 416's Avatar
Site Sponsor
Thanks!!
wonder if thats my 96 on CL in redding? LMAO
and ya it will work I just did that on my 90 use the 96 pump lines and H/B unit have to make new brake lines (30 bucks) and new fittings on the P/S hose to the box (50 bucks) make a line from the oil gally in block to the vac pump (45 bucks)
other than that you will have to drill a 1in hole in your brake leaver (no big deal) and drill 2 holes in your fire wall
took me 4 hours
Old Apr 9, 2011 | 12:20 AM
took me 4 hours
I have a feeling it is! LOL I will be sending you a PM shortly.
Stone007
Aug 2, 2015 05:41 PM
Dec 29, 2014 10:20 AM
Dec 12, 2014 12:30 PM
Nov 16, 2014 06:10 PM
Nov 3, 2014 08:10 AM
