97 cummins loosing power
Old Apr 7, 2011 | 09:56 AM
huntingguy's Avatar
Default 97 cummins loosing power
my engine is pretty much stock, i have 193,000 miles on it and i am loosing power.
when I pull up to a stop light with the AC on the truck will die. When i am accelerating to get on the freeway it has a hard time getting going, usually around 50mph (1.5 rpm) if there is a hill i am loosing speed and i am not even pulling a trailer. the only time i am seeing black smoke is when i start it in the morning. I can hear the turbo spinning.
any idea's anyone has would be a great help.
thanks!
Old Apr 7, 2011 | 02:03 PM
dodgecummines12valv's Avatar
im gust putting this out there win it start in the morning is it hard to start
Old Apr 7, 2011 | 02:12 PM
huntingguy's Avatar
Yes it is hard to start in the morning,
Old Apr 7, 2011 | 04:18 PM
1978skidootnt's Avatar
No smoke fuel delivery problem?
Old Apr 9, 2011 | 07:34 PM
huntingguy's Avatar
i adjusted the idle screw today and it starts much better, I also put a new hi-flow air-filter in it today. i haven't had a chance to take test it but i don't think that is going to help. payday is tuesday and i am going to change the fuel filter and pre filter that's in the fuel heater. if that doesn't work I will change the filter in the tank.
Old Apr 11, 2011 | 04:16 PM
huntingguy's Avatar
changed the prefilter, the fuel filter and oil today but not much change. still feels sluggish and no acceleration no smoke, this truck came out of CA. and has a tube running from the exhaust to the intake manifold if i remove this would it help lower my exhaust temps? and I read something about the wast gate going valve going bad. I have no pressure gauges to check the wast gate I read that it should be at 20p.s.i is there another way to check ant see if it is working?
mesjr
Sep 29, 2015 06:43 AM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
4estlee
Oct 7, 2014 07:47 PM
