It came!
Old Apr 6, 2011 | 08:42 PM
Klockmon's Avatar
Default It came!
My gds 60mm upgrade came.
I'm going to install it, but ive never touched a turbo in my life and am ready to learn something new
It would be awesome if some one who did it could tell me how to do it. Or post a link, I havent been able to find anything. What are the steps to swapping out the compressor upgrade?
Thanks, I'm so excited to put it in, I just really dont want to screw it up.
Thanks alot in advance.
Old Apr 7, 2011 | 10:31 AM
white93's Avatar
HTT Stage IV how-to and impressions - Dodge Diesel - Diesel Truck Resource Forums I've done it many times and its easy but be VERY CAREFUL.
1. The nut has reverse threads and may be hard to break loose.
2. Make sure you use a 13mm wrench and not a socket. For some reason using a ratchet bends the shaft every time, at least it did with me.
3. If you don't get the compressor housing on perfectly straight it will bind with the wheel and bend the shaft. As you slide it on turn the wheel to check for binding.
4. I never use a torque wrench and haven't had any issues. Get it tight but not really tight or you will bend the shaft.
5. These turbo's don't have the strongest shaft but if you careful you should have no problems.
Old Apr 7, 2011 | 12:08 PM
RSWORDS's Avatar
Also look in the sticky. I did a hybrid build mine needed a. Customer crossover but you should not.
Old Apr 7, 2011 | 05:43 PM
Smoke4Broke's Avatar
Yeah I put one on a while back and I really like it. If you don't have a BHAF it doesn't whistle very loud but with one man it sure sings. Also take it nice and slow when doing the install. I didn't have any problems. However, if you're like me and like things clean make sure you either paint the housing or install it with very clean hands or you will smudge grease into it and it wont come out. Found that out the hard way. Nice clean looking housing except for a splotch of grease on it that wont come off .
Good luck
Old Apr 7, 2011 | 06:06 PM
justanother92's Avatar
Hey just wonderin how much for the upgrade and if i should go with the smaller ex housing on my 92 i/c if i do the upgrade, thanks.
Old Apr 8, 2011 | 11:10 AM
Levi Miller's Avatar
hey guys i did the 60mm upgrade a while back befor i blew my turbo and i also had a smaller wastegated exhaust housing on it and all of my buddys named my truck the 727 because when i passed then goin 90 and turning 30 psi even with my 5in straight pipe all they could hear was my turbo butt saddly it died and im running an hx35
Old Apr 8, 2011 | 09:55 PM
Klockmon's Avatar
just another 92,
It cost me 290$, but you could get it cheaper, I got hammered on shipping costs since I live in Canada.
I just put it in, along with my BHAF, and I reccommend it. It screams!
I put mine on with the original housing and im pretty impressed with it. Though, I am going to be putting on a smaller housing in the next couple of months, either a 14 or a 16cm. So if you can do them both at the same time do it, but I wasnt able too at the time.
Old Apr 12, 2011 | 12:19 PM
Hey thanks i think i will try it out when i get a few extra dollars.
