what causes a 2509 code
Old Apr 6, 2011 | 07:00 PM
rednekroper05's Avatar
Default what causes a 2509 code
ok what would cause this code i have seen some say bad ground and some say its the batteries but mine are reading 10v with key on is that the problem.
When turning the key to start it just clicks.
Old Apr 6, 2011 | 07:22 PM
wildbill's Avatar
P2509 ECM/PCM Power Input Signal Intermittent
Need at least 12V to the ECM at all times, otherwise it throws that code. How old are the batteries??
Old Apr 6, 2011 | 07:25 PM
Not sure how old the batteries are.
Old Apr 6, 2011 | 07:32 PM
wildbill's Avatar
Judging on the issue, likely the ones that came with the truck.
Old Apr 6, 2011 | 07:35 PM
No they are not factory batteries I can't remember right off hand but I think one is a super start and the other is a yellow one
Old Apr 6, 2011 | 07:38 PM
wildbill's Avatar
Need to be the same type and cranking amps need to be also. Type as in wet or dry cells, can't run one of each at the same time.
Best bet is to get two new batteries.
Old Apr 6, 2011 | 07:41 PM
thats kinda what i was thinking. also does the odometer stay on all the time on these trucks?
Old Apr 6, 2011 | 07:49 PM
wildbill's Avatar
Odometer come on when:
The drivers side door is open, key or no key in ingnition
Key is in ignition, but switched to accessory
Or the switch is in run, engine running or not
Old Apr 6, 2011 | 07:54 PM
When door opens no key in ignition
Old Apr 6, 2011 | 08:14 PM
wildbill's Avatar
Normal. Service guy can get a reading faster/easier.
