Quadzilla adrenaline
Old Apr 6, 2011 | 05:09 PM
Tdog's Avatar
Default Quadzilla adrenaline
i just put a quadzilla in, i also went into the chip and added the comp tune but the truck still does not seem to have a difference in power levels like level 2 feels the exact same as level 10 any one with any ideas please let me know thanks.
Old Apr 6, 2011 | 07:03 PM
D-LUX's Avatar
not getting enough fuel is more than likely your issue.... you could check your pump tap as well because the box will still add power and timing through the can/bus connection but wont give you the kick in the pants power unless the pump is tapped
Old Apr 8, 2011 | 11:07 PM
BAPilot2's Avatar
I'm agree with you regarding the perceived power output of the Adrenalin levels.
I installed my Adrenalin in late January / early February of this year, 2011, and I too can not really tell any difference of power. Along with the lack of perceived power output vs. power level I am also getting heavy surging anytime I use 50% or more throttle. And I am not producing much smoke at the higher settings which leads me to believe that I am getting erratic fueling or not enough fueling.
Does anyone else have these problems and if so what are the answers?
Old Apr 9, 2011 | 01:33 AM
kegs99's Avatar
tyler, i think its you that posted this article. I did some research and the chip is most likely defueling because it doesn't have enough fuel. the chip is trying to save the injection pump. We need to get your fass hooked up on the truck and that should make the world of difference. I know hooking up my airdog did. check out the price quote area on this site, and tell em you have the pump and need everything else. you'll wanna do the half inch fuel line and the draw straw kit. plus the wiring harness for it, and the hardware to connect into the injection pump.
KatiTrimmell
Jun 13, 2016 12:29 PM
dodge1998
Jun 13, 2016 12:25 PM
Baradium
5.9L 24V Performance
Dec 14, 2014 05:04 PM
MAC4232
Oct 16, 2014 04:22 PM
estill03
For Sale
Oct 3, 2014 09:58 PM
