Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
cant find source of leaking coolant
Old Apr 6, 2011 | 12:53 PM
JS2TZU's Avatar
Default cant find source of leaking coolant
My 05 Duramax is leaking coolant from the middle of the front of the engine. I cant find the source of the leak, and was wondering if anyone had an idea where its coming from?
The thing is it comes and goes its not constant meaning ill go to the store and there will be a huge puddle under the truck and when i get home it wont leak at all. Leave it overnight and theres a small trickle thats under the truck. any ideas?
Thanks in advance
Old Apr 7, 2011 | 04:30 PM
cbsmoraine's Avatar
had the same prob. pulled all the skid plates, looked at every hose i could think of, repositioned some clamps, swaped some clamps (went from the crimp type to the screw type) found a small line off the diff that didnt have a clamp so i clamped it. threw the skids back on and havent seen any coolant yet.
Old Apr 10, 2011 | 07:00 PM
BriteWhiteRam's Avatar
have you looked at your thermostat gaskets? or the coolant crossovers? waterpump?
Old Apr 10, 2011 | 07:10 PM
H.R.D's Avatar
My suggestion to you is get a leak finder kit. It uses a dye the glows under a black light. Here is the kit I have used and works great.
Tracer Products TP8621 Universal UV Leak Finder Kit | eBay
Old Apr 14, 2011 | 12:16 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Water pump maybe? They have a kit that pressurizes the system to help find your leak when the truck is off.
Old Apr 14, 2011 | 05:13 PM
2500HeavyDuty's Avatar
water pump, there is a small coolant hose behind the engine fan. thats about all i can think of
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
dieselpowa
Feb 7, 2015 10:07 PM
97f-250
Nov 23, 2014 08:08 PM
Stox5225
Nov 18, 2014 01:04 PM
