grid heater question
Old Apr 6, 2011 | 09:28 AM
staylorw250's Avatar
Default grid heater question
On my 89 does the grid heater only come on on cold starts or does it come on when the engine temp isn't at a certain point. I no on my dads 24v it comes on untill it is not needed i was just curious but his is a electronic
Old Apr 6, 2011 | 10:58 AM
1989w250's Avatar
The heater on my 89 comes on when i turn the key then when the buzzer stops and the engine is started its off. But if its warm and i go to start it the heater doesn't come on.
Old Apr 6, 2011 | 12:31 PM
alright thanks that is how mine works
Old Apr 6, 2011 | 12:56 PM
NadirPoint's Avatar
Default Both
The IAT sensors (Air Intake Temperature) in the plenum cover are used by the PCM to control the grid heaters and KSB. Non-IC'd trucks have a lower temp setting than the IC'd 1st Gens, but I don't recall the exact numbers. Mine used to come on around 50 degrees, IIRC.
The later trucks use a combination of readings from the intake and the airbox to help the ECM make a decision about the heaters.
dodge2014
Apr 16, 2015 08:54 PM
95 cummin
Jan 21, 2015 11:54 AM
Rooster24v
15
Jan 4, 2015 08:20 PM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
justinsbeck
Nov 22, 2014 03:03 AM
