AirDog Question
Old Apr 5, 2011 | 10:10 PM
Smarty=Cummins's Avatar
Default AirDog Question
So I just put the AirDog 100 on my truck and I was wondering if you could put a bigger sping in the return line. I put the 17 psi one in but could you go bigger. I know if you go to much it will hurt you so whats my limit.
Old Apr 5, 2011 | 10:15 PM
heavy hauler's Avatar
It is not supply pressure at idle that you should be worried about but the pressure or flow that you have under a load or at WOT. If you are holding 13-15 under load or WOT you should be fine and not need a bigger spring. My 150 pushes 18-20 at idle but I can pull it down to 12 at WOT under a pull.
Old Apr 5, 2011 | 10:28 PM
Red_Rattler's Avatar
High Tech Redneck
Correct. More pressure is not always the answer, since it's a measure of restriction not flow.
Jul 21, 2015 09:30 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Jet A Fuel
Jun 5, 2015 03:28 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
