Gasoline in my Cummins
Old Apr 5, 2011 | 06:30 PM
Sieversdiesel's Avatar
Default Gasoline in my Cummins
So i was getting low on diesel so i let my 17 year old son run it down to the store and put 50.00 in it and on the way back it started blowing white smoke and it died in the middle of our street. i asked what had happened and he said that he put Vtech in and drove off.
big trouble or not?
i drained the tank and called a local guy to come and get it.
My question is? is the motor done or not?
Old Apr 5, 2011 | 06:39 PM
prison's Avatar
Vtech? and did you tell him to put gas in? well the motor isnt done but i'd say you could have some trouble with some other things. for example injection pump, lift pump, maybe injectors. depends. i'd drain ever ounce of fluid from the fuel system and throw diesel back in and run her down the road. might work might have some problems with the above mentioned components but try runnin first
Old Apr 5, 2011 | 06:42 PM
kerley's Avatar
I did the same thing two years ago. My 1998.5 Cummins was running lousey anyway, but I did'nt know enough about the Cummins to figure it out. I needed a new lp and vp44. When I accidently filled up with unleaded I got about 1/2 mile and it was all over. $2880. for the repair and towing. I got screwed and left pissed off and still am. Sence then I installed a good set of guages and read everything I can about Cummins/Dodge. I also replaced the new oem lp the repair shop installed for $495.00 with a Fass. My experience was very expensive. I sincerely hope you turn out better than this old man did.
Make sure the repair shop purges the total fuel system and new filters. Good luck, Tom
Old Apr 5, 2011 | 07:02 PM
thanks the tow truck just left. and he is going through the whole fuel system
Old Apr 5, 2011 | 08:03 PM
Whit's Avatar
Site Mascot
https://www.dieselbombers.com/altern...esel-fuel.html
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
Sbboozer
Nov 16, 2014 05:52 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
