12 valve popping..?
alrighty so im just kinda wondering if any other trucks do this or what the problem might be..
when im cruzing along in third or fourth gear at about 2k rpm and then put it to the floor it goes for a second then pops and lets out a big puff of smoke.. or if im in neutral and wick the throttle it revs up then pops and smokes then keep goin... im not sure what it could be.. a surge or lack of fuel maybe?
any thoughts or ideas would be helpful!
super hot egts or tons of unburnt fuel cause that breaking up sounds your talking about, low timing is normally the cause of the soaring egts and breaking up. i know these trucks are pretty common to slip timing so to me that sounds like your problem, id put my money on it.
Its not amount of fuel that causes it. Its the injection time in relevance as to where the piston is. A stock truck can have this issue when cold if the timing has slipped some over time.
sweet deal well not really but thanks for the help fellas!! looks like i need to get on that! i have read about how to time it makes sense. ohh and does anyone know why they lose time? i understand how it happens the pump gear is on a tapered shaft and has no key way so it can spin but is there any factors that might cause this?
and again thanks alot!!
