lift pump leaking
Old Apr 3, 2011 | 08:16 PM
jdbigblue12v's Avatar
Default lift pump leaking
have a leaking lift pump and wodering if it could be a gasket or a bad lift pump. im not great with diesel yet so i dont know what to start replacing first
Old Apr 3, 2011 | 09:57 PM
BIGREDGOAT's Avatar
is it oil leaking or diesel??
Old Apr 4, 2011 | 05:20 PM
its leaking diesel
Old Apr 4, 2011 | 08:34 PM
BIGREDGOAT's Avatar
hmm did you check the lines going into or leaving the pump? do you still have the stock lift pump?
Old Apr 4, 2011 | 10:04 PM
austinward's Avatar
umm most likely its the gasket i had the same problem and it was the gasket if its the original lift pump then is over 20 years old just go and pick up a new lift pump there cheap and it comes with a gasket there easy to replace
Old Apr 5, 2011 | 02:41 PM
yaa its the original lift pump. do you suggest getting a whole new one or a gasket?
thanks
Old Apr 5, 2011 | 11:40 PM
tiremann9669's Avatar
The gasket wouldn't cause it to leak diesel it would cause it to leak motor oil.
Old Apr 6, 2011 | 08:43 PM
austinward's Avatar
just go and get a new one there not that expensive but you really are better off putting in a new pump and a gasket but make sure you find out the proper tourqe specs when u install the new one or eles you will just tear the gasket and have wasted ur mony not to mention wasted your money
Old Apr 6, 2011 | 09:22 PM
ok thanks everyone i willl most likely get a new one and does anyone know a site where i can get the torque specs from?
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
