6.0 pumping oil into cooling system
Old Apr 3, 2011 | 07:48 PM
zokie's Avatar
Default 6.0 pumping oil into cooling system
HELP did egr delete ARP studs black onyx head gasgkets, engine starts after it builds oil pressure within 5 minutes i have no oil on the dipstick! engine runs fine no smoke no smell also it loses oil pressure ater shut down. what i mean if i let it set 5 to 10 minutes i have to crank 20 or 30 seconds to build oil pressure again. then it fires and runs fine but I am building oil water mix in the degas bottle.
Old Apr 3, 2011 | 07:59 PM
heavy hauler's Avatar
Soundsl like your oil cooler is busted.
Old Apr 3, 2011 | 09:00 PM
zokie's Avatar
new oil cooler was thinking the same thing. pulled the oil cooler plugged the coolant in and out pressurized and held under water.... no bubbles??
pressurized each cylinder withe 120lbs of air no air noise in the line returning to the cooling system. I thought maybe i had a problem with the head gasket, when i installed the new ARP studs i had some oil in the holes, didnt think anything of it on the first head. second head i pullled wiped the gasket clean blew out the holes and installed. the first time this happend I pressurized all cylinders and couldnt hear any difference. Just to rule out oil trapped inside the head gasket I pulled the head and replaced with an new one. much to my disappointment same result.
looks like i posted this in the wrong section sorry reposted in the powerstroke section
Old Apr 4, 2011 | 03:07 AM
97cummins's Avatar
Old Apr 4, 2011 | 10:21 AM
sunsetsky's Avatar
Site Sponsor - Black Cloud Diesel Performance
Howdy! Welcome to Diesel Bombers! You're Going to Like it Here!
Old Apr 4, 2011 | 10:52 AM
bad64nova's Avatar
if cooler is good then gasket is damaged
Old Apr 4, 2011 | 02:14 PM
zokie's Avatar
if it was a head gasket wouldnt i be smokin or something?
Old Apr 4, 2011 | 04:02 PM
bad64nova's Avatar
oil cooler gasket might of nicked it
Old Apr 5, 2011 | 02:54 PM
1ATony's Avatar
welcome to the site
yz450f269
Mar 15, 2015 08:56 PM
emilio2496
8
Jan 13, 2015 05:03 PM
ash23k
Dec 30, 2014 08:31 PM
iam1746regan
Dec 21, 2014 05:06 PM
Mopar Mike
Oct 6, 2014 07:51 PM
