question conerning charging system on 06
Old Apr 3, 2011 | 04:19 PM
rednekroper05's Avatar
Default question conerning charging system on 06
What is the cable that goes from the postive aux. battery post to the selenoid mounted below it called.
Also what would cause this wire to mealt the coating and the wire has a whiteish look to it?
Old Apr 3, 2011 | 04:55 PM
wildbill's Avatar
Small cable coming off the battery to a solenoid, pass side?
Old Apr 3, 2011 | 05:11 PM
Yup that's the one. The coating is mealted back and the wire has that whiteish color that metal gets when it has been burnt.
Old Apr 3, 2011 | 05:45 PM
wildbill's Avatar
That's for the grid heater.
Old Apr 3, 2011 | 05:57 PM
Ok the light on the dash has been coming on and going off since I bought it why would that be happening. Also would this drain my batteries both down?
Old Apr 3, 2011 | 06:02 PM
wildbill's Avatar
Light shouldn't be flashing, only comes on when the grid heater is needed. The volt gauge will fluctuate though. May want to have the starting/charging system tested though. Any parts store will do it for free.
Old Apr 3, 2011 | 08:28 PM
coors_man_2005's Avatar
if its to the grid heater maybe a bad grid heater and its shorting out inside there which caused to melt the wire just a thought dunno??
Old Apr 5, 2011 | 12:10 AM
Will it hurt anything if I just take that cable off for now and run the truck?
Old Apr 5, 2011 | 06:38 AM
if its just for the grid heater i dont see why it would except for harder starts in the cold weather
Old Apr 5, 2011 | 09:21 AM
dangerous1965's Avatar
Check where the wire ties into the grid heater. You have or had a short to ground. As long as your above freezing your ok to disconnect it. But it will throw a code.. It will drain your batteries! get it fixed asap.
Jet A Fuel
Aug 3, 2015 10:45 AM
Adell Bob
Mar 23, 2015 12:39 AM
JRB1960
Dec 1, 2014 09:24 PM
Jreeb
Oct 20, 2014 01:31 PM
Mopar Mike
Oct 6, 2014 07:51 PM
