heating up diesel?
Old Apr 2, 2011 | 12:21 PM
vost's Avatar
Question heating up diesel?
Are there any advantages to heating up diesel. and dose anyone know if you have to heat up WMO to run in a engine.
Old Apr 2, 2011 | 12:39 PM
RAW's Avatar
RAW
The only reason to heat diesel is to prevent gelling in cold weather to aide in starting and running.
Old Apr 3, 2011 | 01:19 PM
Deezel Stink3r's Avatar
Thoughts and facts 'bout this:
Diesel expands if you heat it up.
Experimented with it already: 5 ml of diesel 20°C (68°F) room temperature and expanding to 7ml at 80°C(176°F) measured with a chem lab burette.
This the reason why the VW Phaeton has a fuel cooler behind the IP.
The Diesel is heated up by the extreme pressure of the IP.
Inside of most modern IP's you will also find a temperature sensor for fuel temperature compensation.
That means cold fuel is denser and contains as a result more BTU's by weight. If you heat the fuel you have to inject more fuel to get the same amount of BTU's.
So the engine injects more fuel with heated up fuel- this could lead to an increase of fuel consumption by approximately 30%
The only advantage might be a smoother engine run.
BUT: If you have an VP44 heat is poison for the IP. They are known for heat failure.
Old Apr 3, 2011 | 06:37 PM
BriteWhiteRam's Avatar
heat isnt too good for the PMD in the 6.5TD either
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Strictly Diesel
Strictly Diesel
Jun 30, 2015 06:48 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
