89 building up too much pressure
Old Mar 31, 2011 | 10:54 PM
schmidt's Avatar
Default 89 building up too much pressure
my 89 7.3 is building up too much pressure and causing blow by why is it doin this??? its confusing the heck outa me!
Old Apr 1, 2011 | 01:20 PM
DieselCrawler's Avatar
from the factory these engines have blowby at idle. rev it up, does it go away?
Old Apr 1, 2011 | 07:02 PM
schmidt's Avatar
na ill be drivin down the road and itll start doin it, sometimes itll do it sometimes it wont but its doin it alot more now. and its loud as hell
Old Apr 1, 2011 | 10:39 PM
how can you see blowby driving down the road?
Old Apr 1, 2011 | 10:46 PM
prison's Avatar
exactly what i was thinking....
Old Apr 2, 2011 | 10:14 PM
schmidt's Avatar
cause ill pull into a lot and check it while its still doin it
Old Apr 2, 2011 | 10:18 PM
prison's Avatar
if you pull into a lot your not driving though. check it when its revved above idle
Old Apr 2, 2011 | 10:26 PM
the cdr valve on these engines does not flow alot at idle. anything above idle and it will pull crankcase gasses into the intake and burn them off. where is the blow by coming out of?
Old Apr 3, 2011 | 02:05 PM
schmidt's Avatar
it blew out my head and valve cover gaskets and thats where ive felt it blowin out of
Old Apr 5, 2011 | 10:36 PM
schmidt's Avatar
nevermind i fixed it
