thinking i have an electrical draw some where
Old Mar 31, 2011 | 03:48 PM
jdbigblue12v's Avatar
Default thinking i have an electrical draw some where
i have a brand new battery i the truck and it works fine if i run the truck everyday for more than 15 minutes, but if i dont start the truck, the battery dies and i cant get it started. i think i have a small draw some where but do not know where to look.
Old Apr 1, 2011 | 05:36 PM
dragrdan's Avatar
make sure everything electrical is off, disconnect a battery lead, connect a test light in between the battery post and the disconnected lead. If it lights up, you have a draw. First place I would look is underhood light, and glovebox light. If they are ok, pull 1 fuse at a time till the test light goes out. Now you know what circuit it is on.
Old Apr 1, 2011 | 06:58 PM
RAW's Avatar
RAW
A test light will light up regardless if there is a parisitic drain or not. Sustitute the test light for a multimeter, and measure the amperage. Rule of thumb is 30mA (Milliamps) is max. My '01 has 10mA with just the truck and radio hooked up. More with a brake controller (adds 10mA), and Viper command start (adds 32mA).
Old Apr 1, 2011 | 07:31 PM
2500HeavyDuty's Avatar
yup, use an multimeter, test lights are for cavemen
Old Apr 2, 2011 | 12:08 PM
thanks i will try doing this later on today when i get a chance and get back to you
coryfast
Jul 6, 2015 06:02 AM
duramaxtuner
Dec 10, 2014 01:24 PM
91 7three
Dec 1, 2014 08:18 AM
Baradium
Nov 21, 2014 08:20 AM
Kentonjl
Sep 30, 2014 07:22 AM
