NorCal DODGE CUMMINS 12v 6cyl motor with 5spd trans SWAP
Old Apr 1, 2011 | 12:30 AM
chico_mustangs's Avatar
Default NorCal DODGE CUMMINS 12v 6cyl motor with 5spd trans SWAP
CUMMINS ENGINE & 5SPD MANUAL TRANS
This was removed from a running 1993 Dodge Ram 350 1 ton two wheel drive with just over 200k on it. It ran great and has a set of new performance injectors in it. The motor did leak oil from all the normal places as these Cummins motors always do. I planned on using this swap for a project but have decided to hold off on it for a while. The 5spd transmission worked flawlessly with no grinding, howling, or anything of the sort. The clutch held great with no slipping or excessive force in pedal pressure.
This includes the engine, trans, wiring, computer, all accessories, belt, clutch, flywheel, pressure plate, 5spd pedal assembly, clutch master cylinder, etc.
If you have any questions or would like a shipping quote please email me with your city, state, zip code, whether its a business or residence ship to address, and if their is either a forklift or loading dock at that location.
PLEASE MAKE ME A REASONABLE OFFER, I am not sure what these are going for. I am located in Chico, Ca and let me know if you want to come see it for yourself.
ttt
Last edited by chico_mustangs; Apr 1, 2011 at 12:30 AM. Reason: Automerged Doublepost
Jonrarick
Oct 25, 2016 01:32 PM
torino73
Apr 14, 2015 11:15 PM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
