Help!
Old Mar 30, 2011 | 07:01 PM
motoxer301's Avatar
Default Help!
Hey Guys need some help on this one.....after my injector install I took it for a ride and everything was fine, until I got back to my house with it and saw coolant leaking pretty bad.....turns out its coming from a small freeze plug in the back left hand side of the motor.....how do I fix this?
Old Mar 30, 2011 | 08:51 PM
TugBoat's Avatar
POP it out n put new one in
Old Mar 30, 2011 | 08:58 PM
motoxer301's Avatar
do you think it will happen again without having the head o-ringed and all that because of the injectors?
i found this pic online, its the same freeze plug that is leaking on my truck....
http://www.laserbytes.com/images/24vleak.jpg
Last edited by motoxer301; Mar 30, 2011 at 08:58 PM. Reason: Automerged Doublepost
Old Mar 30, 2011 | 09:05 PM
oudive's Avatar
motoxer,
What size injectors did you put in? I would not think that the freeze plug started leaking b/c of injector swap. It may had already started to give and it finally gave up on life. I would swap it out with a new one and keep an eye on it. Good luck on it and I hope that once you swap it out, it is good to go and you can enjoy your new injectors.
oudive
Old Mar 30, 2011 | 09:51 PM
motoxer301's Avatar
oudive,
I put 150hp injectors in it....i never had a problem with coolant leaking in the past....i took it out for a ride as soon as they were done to see the difference they made and as soon as I got back there was a large puddle of coolant under the truck.....it sucks because its almost impossible to get at being in the very back.....in my head i keep thinking the injectors had something to do with it
Old Mar 31, 2011 | 08:12 AM
TugBoat's Avatar
Like oudive said it was prob on way out. Any that extra lil beating u gave it pushed it out. Clean it up nice n smash a new one in. It's tight but can be done.
Old Mar 31, 2011 | 01:38 PM
motoxer301's Avatar
Do you think I should have the head o-ringed and get head studs?
Old Mar 31, 2011 | 09:47 PM
TugBoat's Avatar
If you plan to do some upgrades yea, can't hurt the truck.... only ur pockets
Old Apr 1, 2011 | 07:52 AM
motoxer301's Avatar
I do plan on upgrading the turbo, maybe stacking an edge comp box with my smarty but that's it.....I did get a price on getting the head o-ringed and getting head studs.....quite expensive, good thing I was sitting down
Old Apr 1, 2011 | 07:55 AM
RAW's Avatar
RAW
A set of studs alone will go a long way. That's all I'm planning to do on my truck. I also have a set of 150's sitting beside me that will go in at the same time.
